LayerList with Symbology
2758
03-08-2021 10:10 AM
DianeBird
I'm using the layerlist with a legend sample. We have a large datasets in our webmap, and it seems to be clumsy  for the legend to appear at the top of a grouped layer set for those layer items turned on with all the listed layers down below in order to turn off the layer. This creates a lot of scrolling back and forth. Is there a way to incorporate the legend under the layer name with the on/off button on the same line? In other words, the legend would appear when the layer is turned on without creating a separate listing of legend items at the top of the open window.
deepakbharadwaj
Hi DianeBird
If you are looking for Arcgis  Javascript api 4.x solution. Please find link below from ESRI Arcgis Javascript API 4.xfor your reference.
URL: https://developers.arcgis.com/javascript/latest/sample-code/widgets-layerlist-legend/
DianeBird
I am using the sample code from that widget and this is what I get:
I do not want to see the same layer listed below the legend.  That requires a lot of scrolling through the list to manage visibility of layers.  I would like to see one list of the layers with the symbology right under the name of the layer. Presented much like the mxd's are.
Strahanjen
Did you ever find a solution or work around for this? I'm having the same issue.
