Labeling Chart with FieldName Alias or Manually
2061
11-23-2021 01:20 PM
albanajpaul_itotem
Is it possible to label the charts in the popup with its respective aliases or do I have to rename my fieldname in the featureservice. Is it also possible to add the y axis labels for the chart? I'm using ChartMediaInfo to create this chart
RickeyFight
@albanajpaul_itotem
How are you adding the data? If via a webmap try renaming the fieldname there.
albanajpaul_itotem
@RickeyFight
The data is added by featurelayer through  a featureservice url, I want to be able to use the character '&' in the labels but i dont think its going to be possible if I have to rename the fieldname
