Labeled feature layer with popups: label blocks selectable space in polygons
1750
01-24-2017 09:34 AM
brianmoran_usfs
I have a pretty simple map showing a feature layer of polygons with labels.  The features can be clicked to display a popup with some formatted info.  However, the labels are not selectable, and they cause a blind spot in the clickable area of the polygon.  Is it possible to give the labels themselves the same popup functionality as their associated features?  It is a problem for me because the labels take up a fairly large portion of the polygons, making it difficult to click in the right place to display the popup.
KenBuja
MVP Esteemed Contributor
Which version of the API are you using? 3.x or 4.x? Are the labels a part of the feature layer or are those being added separately?
brianmoran_usfs
Version 3.19.  The labels are part of the feature layer, added with the setLabelingInfo method.
The map can be viewed here-- note the rollover is blocked out by the polygon labels-
https://www.fs.fed.us/r5/webmaps/VisitorMapFootprints/
