Label expression doesnt work
4114
15
12-03-2018 12:54 PM
EvelynHernandez
Hello everyone,
Im having a problem with a label expression in ArcMap that we have setted up.
As u can see, we added a label exp in VScript that works in Arcmap but when we go to the mapview that we made, the layer is showing the datetime in another way (not with the logic we put it the expression).
What could be happening?
Thanks in advice.
EvelynHernandez
No. They dont.
EvelynHernandez
RobertScheitlin__GISP
Evelyn,
   Then the map service is not capable of displaying the complex label expression. It has nothing to do with the Javascript API. When you published this service did you not get some warning about this?
EvelynHernandez
Uhm no, we didnt see any
I would contact tech support. I believe that it is just a label expression limitation of a map service that you are encountering.
EvelynHernandez
OK. Let me know if u find something
Thanks
