kriging javascript
2134
10-13-2019 10:27 AM
SergioFerlito
I would like to know if it is possible to use ArcGIS Javascript to create a map from GeoJSON data and interpolate features using IDW or Kriging (bayesian). Perhaps is it possible only using REST API for geoprocessing?
I found something similar here, but not exactly what I was looking for.
Any example code at this regard?
This type of spatial analysis can be performed with a free developer account ?
Thanks.
BenElan
Esri Alum
Hi Sergio,
Point Interpolation can be done from the REST endpoint. You can replace the geoprocessing service in the example you found with the Point Interpolation one. Point Interpolation costs 1 credit ($0.10 USD) per 1000 features.
In terms of points from a GeoJSON, I created a sample a while ago that may help.
SergioFerlito
Thanks!
