Known issues when using 'LAYER_OPTION_VISIBLE' parameter in identify task?
1029
06-09-2011 03:33 AM
ChrisBuckmaster1
Hi
Just wondering if anyone is using the visible layer option parameter successfully in an identify task to identify just those layers visible on the map?
I cannot seem to get it to work and came across the same issue in this thread (http://forums.esri.com/Thread.asp?c=158&f=2396&t=261892)
I tried using the following code as mentioned but this didn't help:-
identifyParams.layerIds=myDynamicMapServiceLayer.visibleLayers;
Any suggestions?
Thanks!
JeffPace
If you are specifying layerids (and determining layerids from the service) , i think you should be specifying
identifyParams.layerIds = myDynamicMapServiceLayer.visibleLayers;
identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL;
otherwise i think you would leave out the ids and just say
identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_VISIBLE;
