Knowing the polygon id and getting the extent
1102
05-26-2013 10:13 PM
PrasannaRaghavendar
I have a text box where I have the polygon Id like,
"id_of_the_polygon_12345"
. Is it possible to get its extent on the map and zoom into it? I have figured out how to do it upon clicking on the map. But could not figure how to do the same knowing my poly Id.
VinayBansal
Could you elaborate more on your functionality, what actually you want to do?.
PrasannaRaghavendar
I know that I can zoom to a polygon when it is clicked by doing this
identifyParams.geometry = evt.mapPoint;
identifyParams.mapExtent = map.extent;
identifyTask.execute(identifyParams, function(result) {
     var i;
     var polyId= new Array();
     for(i=0; i<result.length;i++){
       polyId=result.feature.attributes["UNIQPOLYID"];
But I do not want to do it upon clicking on the map. When the user enters the polygon id in a text box, I want to zoom and show that polygon on the screen.
VinayBansal
Means you need to query based on the polygon Id.
For that you need to use query task
You can take input from this sample on how to call query task on layer you want to query
http://help.arcgis.com/en/webapi/javascript/arcgis/jssamples/query_nomap.html
Once you got the results, get the geomtry and zoom to its extents on map.
