Kinetic Panning Via The ESRI JavaScript API
11293
35
09-29-2012 11:37 PM
jeffpalus
Just to be consitent with other ESRI web mapping API's, please add kinetic scrolling (aka inertia scrolling) feature, like the way the map pan move in bing & google maps. When you pan around on the map, the expected behaviour is for the map the continue to slide proportionally to the speed you dragged/panned the map.
When the user drag the map, the map moves smoothly.
When the user release the left mouse button the map does not stop straight, but stops by the power of dragging the map you made.
ryanmordoff
Hello all, here is the link to my implementation.  Let me know if you have any issues/comments.
Source - https://github.com/rymor/esri-kinetic-panning
Live Demo - http://rymor.github.io/esri-kinetic-panning/index.html
mykLT
Thank You for sharing. I used params displacementMouseMultiplier: 15 and deceleration: 0.85 for best effect.
I found one issue: if KineticPanning module is created after map is loaded - it works incorrectly (if two mouse drags are done one after another, first panning effect is stopped and second is starting from previous extent).
MarkHoover
Any plans to get this working for IE 8 or any idea why it doesn't?  Sadly, it is the current default browser installed on machines throughout my company.  Works great on IE 9 though!
ryanmordoff
Thanks for pointing out the issue.  I will look into it and try to get it resolved in a couple of days.
ryanmordoff
Yes, my plan is to get it working in ie8, haven't had a chance to troubleshoot it yet though.  I will reply back once I get it fixed.
mykLT
I noticed that map parameter should not be passed for mouseEvents and touchEvents, because they generate map click events and this can cause problems (for eg. draw toolbar is connecting on map click event to handle draw ending).
Also it fails when trying to zoom at panning time. Zooming begins from first pan movement point.
ryanmordoff
Thanks, adding to my list of bugs.
SteveCole
Honored Contributor
Wow. +100 internets to you, Ryan for this. So much better than the default panning behavior. I also need to support pre IE-9 so I'll wait on the sidelines until you get that bug worked out. Great job!
ryanmordoff
Hey, glad you like it.  Go ahead an give it another try, it should be working on ie8 now.
If anyone else has any issues, go ahead and fill out an issue for the project and I will get to them when I can - https://github.com/rymor/esri-kinetic-panning/issues
MarkHoover
Is the live demo no longer working?  I can't seem to access it.
