Kill infoWindow
5277
14
03-25-2011 10:33 AM
ReneeMaxwell
I'm using the editing dijits and I'd like to turn off the infoWindow. I have a query for related records that fires whenever a feature is selected, and this query then populates a form that I have built on the page. I do NOT need the infoWindow but I can't figure out how to turn it off.
KellyHutchins
Esri Notable Contributor
When you create the map set the showInfoWindowOnClick option to false to disable the info window. Here's a code snippet that shows this:
map = new esri.Map("map", {
          extent: esri.geometry.geographicToWebMercator(new esri.geometry.Extent(-125.90, 44.60, -114.65, 50.22, new esri.SpatialReference({wkid:4326}))),
          showInfoWindowOnClick:false
ReneeMaxwell
Thanks Kelly! I appreciate the tip. Unfortunately it didn't work. I added that to my init() function but the infoWindow still pops up.
ReneeMaxwell
FWIW, I wonder if this is a related issue - I can't get my map to enable zooming with the scroll wheel either. It appears that my map settings are having no effect whatsoever.
        enableScrollWheelZoom: true,
Any ideas as to why these settings are not being honored?
KellyHutchins
I re-read your initial post and this is because you are using the editor. The editor uses the info window to display attribute information. Can you tell me a bit about how you are using the editor, for example are you using it just to create new features - or are you using the toolbar etc?
ReneeMaxwell
I am not using the editor toolbar, but I am using the template picker. I'm using it to create new features and to edit feature attributes. However, most of the attributes are all housed in related business tables so I'm using a lot of custom code.
I don't want to use the infoWindow for a couple of reasons. First, it's not big enough to edit all the fields I need to display. Second, it's location is related to the position of the feature on the screen, and this often means that it gets cut off if the feature is near the top of the screen.
KellyHutchins
enableScrollWheelZoom isn't set via the Map's constructor. Try this after the map is created.
map.enableScrollWheelZoom();
You can find more details about map navigation here:
http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jshelp_start.htm#jshelp/intro_navigation.htm
ReneeMaxwell
That was my original code. That doesn't work either.
KellyHutchins
You have to wait until the map is loaded for this to work, are you doing something like this?
dojo.connect(map, "onLoad", function() {
KellyHutchins
Although scrollWheelZoom should be enabled by default so perhaps there is something else going on in your case. If you run one of the samples can you use your mouse scrolling to zoom?
