Hi, is there a way to keep multiple popup windows open?
The default behaviour is the Map instance always ensures there is one Popup / InfoWindow open, such as when user clicks the features on a feature layer that has a Popup configured with it.
My requirement is I need to keep all the popup windows open.
I am using ArcGIS for JavaScript API 3.x.
Henry,
The maps Popup dijit is a singleton type object so no you can not have more then one open on the map.
In the end, I ended up creating my own "popup" / "InfoWindow" with good old plain HTML DIV elements, so they can stay open on the map and I can do whatever i want with them.
Henry,
