keep dijit menuitem open after select
6637
15
07-26-2016 12:03 PM
BrianFoley1
I have a table of contents (TOC) with a legend that allows me to turn on/off layer in my map.  I placed my the TOC in a dijit menubar across the top of my page. When I make a selection from the TOC to turn on/off a layer, I want the TOC to stay opened, but it closes immediately after I select a layer.  Any ideas ?
RobertScheitlin__GISP
Brain,
  Sure here is a sample:
<!DOCTYPE html>
<html>
<head>
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
    <title>TOC</title>
    <link rel="stylesheet" type="text/css" href="https://js.arcgis.com/3.17/dijit/themes/claro/claro.css">
    <link rel="stylesheet" type="text/css" href="https://js.arcgis.com/3.17/esri/css/esri.css" />
    <link rel="stylesheet" type="text/css" href="agsjs/dijit/css/TOC.css" />
    <style>
        html,
        body {
            height: 98%;
            width: 98%;
            margin: 0;
            padding: 5px;
            font-family: helvetica, arial, sans-serif;
            font-size: 90%;
        #header {
            position: fixed;
            top: 0;
            width: 100%;
            height: 50px;
            left: 0;
            background: silver;
        #content {
            position: fixed;
            top: 32px;
            width: 100%;
            height: 100%;
            left: 0;
            margin: 0;
            border: 0;
        #footer {
            position: fixed;
            bottom: 0;
            width: 100%;
            height: 35px;
            left: 0;
            background: silver;
        #map {
            position: fixed;
            width: 100%;
            height: 100%;
            border: 0;
            margin-left: -15px;
            margin-top: -15px;
            margin-right: -15px;
        #tocDiv {
          background-color: silver;
          padding: 8px;
          overflow: auto;
          max-width: 600px;
          max-height: 500px;
        .IdentifyIcon {
            background-image: url("images/Identify.png");
            background-repeat: no-repeat;
            width: 18px;
            height: 18px;
            text-align: center;
        .FindIcon {
            background-image: url("images/query.png");
            width: 18px;
            height: 18px;
            text-align: center;
        .claro .dijitButton .dijitButtonNode,
        .claro .dijitDropDownButton .dijitButtonNode,
        .claro .dijitComboButton .dijitButtonNode,
        .claro .dijitToggleButton .dijitButtonNode {
            border: 0;
            padding: 2px 4px 4px 4px;
            color: #000000;
            border-radius: 0;
            box-shadow: none;
            background: none;
        .claro .dijitMenu {
            border: 1px solid gray;
    </style>
    <script type="text/javascript">
        var djConfig = {
            paths: {
                agsjs: "/js/agsjs"
    </script>
    <script src="https://js.arcgis.com/3.17/"></script>
        var map, toc, basemap, dynaLayer1, dynaLayer2;
        require([
            "dojo/dom",
            "dojo/parser",
            "dojo/on",
            "dojo/_base/lang",
            "esri/map",
            "esri/geometry/Extent",
            "esri/layers/ArcGISTiledMapServiceLayer",
            "esri/layers/ArcGISDynamicMapServiceLayer",
            "agsjs/dijit/TOC",
            "dijit/form/DropDownButton",
            "dijit/DropDownMenu",
            "dijit/MenuItem",
            "dijit/layout/BorderContainer",
            "dijit/layout/ContentPane",
            "dojo/domReady!"
        ], function(dom, parser, on, lang,
            Map, Extent, ArcGISTiledMapServiceLayer, ArcGISDynamicMapServiceLayer,
            TOC, DropDownButton, DropDownMenu, MenuItem) {
            parser.parse();
            var initialExtent = new Extent({
                xmin: -8119646.38042271,
                ymin: 4986891.42830988,
                xmax: -8102329.13378822,
                ymax: 4999699.14992532,
                "spatialReference": {
                    "wkid": 102100
            map = new Map("map", {
                extent: initialExtent,
                smartNavigation: false,
                slider: false
            basemap = new ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer");
            map.addLayer(basemap);
            dynaLayer1 = new ArcGISDynamicMapServiceLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/NapervilleShelters/MapServer", {
                opacity: 0.8
            dynaLayer2 = new ArcGISDynamicMapServiceLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/LocalGovernment/Recreation/MapServer", {
                opacity: 0.8
            var h = map.on('LayersAddResult', lang.hitch(this, function(results) {
                dynaLayer1.setVisibleLayers([0]);
                dynaLayer2.setVisibleLayers([0, 1]);
                try {
                    toc = new TOC({
                        map: map,
                        layerInfos: [{
                            layer: dynaLayer1,
                            title: "Contaminated Areas",
                            collapsed: true,
                            slider: false
                            layer: dynaLayer2,
                            title: "Other Constraints",
                            collapsed: true,
                            slider: false
                    }, 'tocDiv');
                    toc.startup();
                    toc.on('load', function() {});
                    toc.on('TOCNodeChecked', function(rootLayer, serviceLayer, checked) {});
                    h.remove();
                    var myButton = new DropDownButton({
                        label: "Map Feature List",
                        dropDown: toc
                    dom.byId("header").appendChild(myButton.domNode);
                    var menu = new DropDownMenu({ style: "display: none;"});
                    var menuItem1 = new MenuItem({
                        label: "Identify Feature",
                        iconClass:"IdentifyIcon",
                        onClick: function(){ alert('Identify'); }
                    var menuItem2 = new MenuItem({
                        label: "Find Building",
                        iconClass:"FindIcon",
                        onClick: function(){ alert('Find'); }
                    menu.addChild(menuItem1);
                    menu.addChild(menuItem2);
                    var myButton2 = new DropDownButton({
                        label: "Identify Tools",
                        dropDown: menu
                    dom.byId("header").appendChild(myButton2.domNode);
                } catch (e) {
                    alert(e);
            map.addLayers([dynaLayer1, dynaLayer2]);
    </script>
</head>
<body class="claro">
    <div id="content" data-dojo-type="dijit/layout/BorderContainer" design="headline" gutters="true">
        <div id="tocDiv" style="display: none;"></div>
        <div id="header"></div>
        <div id="map" data-dojo-type="dijit/layout/ContentPane" region="center"></div>
    </div>
    <div id="footer"></div>
</body>
</html>
BrianFoley1
Geez Robert that was quick.
As I was thrown into the deep end on this project, with very little experience, your help is greatly appreciated.
BrianFoley1
Robert,
Do you know how to change the font size for the layer title in the TOC ?
Brian
KenBuja
MVP Esteemed Contributor
This would be a good time to learn how to use the developers tools (Chrome, Firefox, IE, Edge) within your browser. All of them have tools to inspect elements on your page, where you can see which CSS rule is used.
Brian,
  What Ken is talking about is (for example in Chrome) you would right click on the layer title in the TOC and choose "Inspect", which would bring up the browsers developer tools and select the span element
<span data-dojo-attach-point="labelNode" class="agsjsTOCRootLayerLabel">Contaminated Areas</span>
Then you would look at the class attribute and see that it is assigned "agsjsTOCRootLayerLabel" then you look for the css rule and file that the rule is coming from (see image):Untitled-2.jpg
Now you know you need to look in the TOC.css line 22 to find this css rule and edit it.
BrianFoley1
Robert,
I just looked at that now. That is extremely helpful. Thanks.
Brian
