Karma error: __esri is not defined
2743
02-17-2020 08:16 AM
ShaneBuscher1
Running into this error when trying to run Angular 8 tests against components containing ArcGIS API for JavaScript 4.12 Typescript types. Any ideas or guidance on how to set up Karma with Angular? Tom Wayson Andy Gup
AndyGup
Hi Shane, it's a known issue. We'll be looking into this over the next few weeks along with migration to Angular 9, here's the issue to track: Webpack example running tests fails · Issue #49 · Esri/angular-cli-esri-map · GitHub
ShaneBuscher1
Thank you for the update Andy!
