Jvascript version 3.3 not working
2307
02-19-2013 05:49 AM
BenStewart
I had an issue with a previous map's symbology (http://forums.arcgis.com/threads/77714-Symbology-not-correct-from-ArcGIS-Online-Map) and I solved it by changing the javascript version to 3.3 (from 3.1). While that worked on Friday, it is broken now.
If you visit my testing page (below), the map tiles are arranged diagonally all across the page. I can't understand what happened between today and Friday. I have created a demo using the 3.1 API version (below) that shows working map tiles (but broken symbology). Please help!
Original AGO map: http://bit.ly/WN0ZmP
3.3 Version: http://geographyis.com/testing/gafsp/GAFSP/countryPage.html
3.1 Version: http://geographyis.com/testing/gafsp/GAFSP/countryPage31.html
KellyHutchins
Esri Notable Contributor
You need a reference to the esri.css file added to your app:
   <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/js/esri/css/esri.css">
We added it in version 3.2 - here's info from the What's New at 3.2 doc:
http://help.arcgis.com/en/webapi/javascript/arcgis/jshelp/#new_v32
KellyHutchins
BenStewart
Thanks, that took care of it, although I don't know why it was working on Friday and not today. Did something change in the .css recently? We have a reference to a local copy of esri.css (not in the demo pages I linked), but it doesn't appear to be working.
Regardless, thanks again for your help and quick responses!
KellyHutchins
Nothing has changed in the css - we only do updates when there is a release.
KellyHutchins
Try clearing your browser cache and see if that resolves the issue.
