jsPanel 2.5.5 does not work with javascript api 3.14
2806
10-15-2015 01:23 PM
abukhan
HI
I tried to use jsPanel 2.5.5 with javascript api 3.14, but it did not work..
Did any body try this?
or any other floating panel that goes with javascript api 3.14
Tags (1)
AkshayHarshe
Hi abu khan,
I was wondering if you have tried using dojo Floating pane?
You can use this to open floating panel.
dojox.layout.FloatingPane — The Dojo Toolkit - Reference Guide
You can also check the attached sample to see how this can work.
Akshay Harshe
Akshay Harshe
