I have JSON Web Service which need to show on Dynamic Map with point Graphics so, when i click on point graphics which are appear on Map it should be show data of Json Service into Info template. I have define all thing in code as per my knowledge and i can see the json data at the time of debugging but when i call it i get error length property . am sharing code any one help predicated.
My code:-
<script src="https://js.arcgis.com/3.23/"></script>
<script src="http://ajax.googleapis.com/ajax/libs/jquery/1.7.1/jquery.min.js" type="text/javascript"></script>
<script> var dojoConfig = { parseOnLoad: true }; </script>
<script>
var map; var mis_rec = [];
var mis_recPoly = []; var gis_rec = []; var attributes = [],point,pointData;
require(["esri/map",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/layers/ImageParameters",
"esri/InfoTemplate",
"dojo/dom",
"dojo/on",
"dojo/dom-class",
"dojo/_base/json",
"esri/config",
"dojo/_base/lang",
"esri/request",
"esri/geometry/Point",
"esri/symbols/SimpleMarkerSymbol",
"esri/graphic", "esri/layers/GraphicsLayer",
"dojo/domReady!" ],
function (Map, ArcGISDynamicMapServiceLayer,
ImageParameters,InfoTemplate, dom,
on, domClass, dojoJson, esriConfig,
esriRequestlang,esriRequest,Point, SimpleMarkerSymbol,
Grahpic, GraphicsLayer) {
esriConfig.defaults.io.corsEnabledServers.push("ncog.gov.in");
map = new Map("mapDiv", {
sliderOrientation : "horizontal"
var imageParameters = new ImageParameters();
imageParameters.format = "jpeg"; //set the image type to PNG24, note default is PNG8.
//Takes a URL to a non cached map service.
var dynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer("http://10.1.31.13/arcgis/rest/services/Thematic_Atlas/DVA/MapServer",
"opacity" : 1,
"imageParameters" : imageParameters
var polygraphlayer = new GraphicsLayer();
map.addLayers([dynamicMapServiceLayer,polygraphlayer]);
dojo.connect(map,"onLoad",_ajaxcall);
function _ajaxcall(gis_rec) {
//document.getElementById("bodyloadimg").style.display = "block";
$.ajax({
type: 'GET',
url: "https://ncog.gov.in/JSON_webservice/get_food_data?code=7654",
crossDomain: true,
success: function (dat) {
mis_rec = [];
mis_recPoly = [];
point = new Point();
pointData = dat.point;
for (var j = 0; j < pointData.length; j++) {
var attributes = [];
for (var i = 0; i < pointData.children.length; i++) {
var chk = pointData.children[1].nodeName + "=" + pointData.children[1].innerHTML;
attributes[pointData.children.nodeName] = pointData.children.innerHTML;
mis_rec.push(attributes);
} // var polygonData = dat.getElementsByTagName('polygon');
gis_mis1(mis_rec);
error: function (err) {
//document.getElementById("bodyloadimg").style.display = "none";
alert(err.statusText); }
function gis_mis1(mis_rec) {
clearGraphics();
for (var i = 0; i < mis_rec.length; i++) {
if (mis_rec.log && mis_rec.lat) {
var pt = new Point(Number(mis_rec.log), Number(mis_rec.lat), new SpatialReference({ wkid: 4326 }));
// if (mis_rec[name]>0) {
var markersymbol = new PictureMarkerSymbol('images/hos.png', 18, 22);
var attr = mis_rec;
//{ "Activity": activity.activityName, "Activity Code": activity.activityCode };
var content = ' <table>';
content += "<tr><td><b>District Id</td></b>" + "<td><b>: </b></td><td> ${dist_id}</td></tr>";
content += "<tr><td><b>Email Nodal</td></b>" + "<td><b>: </b></td><td> ${email_nodal}</td></tr>";
content += "<tr><td><b>State Id</td></b>" + "<td><b>: </b></td><td> ${st_id}</td></tr>";
content += "<tr><td><b>Total Land</td></b>" + "<td><b>: </b></td><td> ${total_land}</td></tr>";
content += "<tr><td><b>Industrial Name</td></b>" + "<td><b>: </b></td><td> ${industrial_name}</td></tr>";
content += "<tr><td><b>Land Area</td></b>" + "<td><b>: </b></td><td> ${land_area}</td></tr>";
content += "<tr><td><b>Nodal Name</td></b>" + "<td><b>: </b></td><td> ${name_nodal}</td></tr>";
content += "<tr><td><b>EHR</td></b>" + "<td><b>: </b></td><td> ${EHR}</td></tr>";
content += "<tr><td><b>Id</td></b>" + "<td><b>: </b></td><td> ${id}</td></tr>";
content += "<tr><td><b>Category</td></b>" + "<td><b>: </b></td><td> ${category}</td></tr>";
content += '</table>';
var infoTemplate = new InfoTemplate('Land Info', content);
polygraphlayer.add(new Graphic(pt, markersymbol, attr, infoTemplate));
var gl = new GraphicsLayer({ id: "st_id" });
map.addLayer(gl);
Anuj,
Here is your code modified to work. I did not have access to some things in your code so I adjusted because of that. Your biggest issue was you were not specifying the dataType of the ajax call and then you were parsing it wrong.
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>Create web map from id</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.24/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.24/esri/css/esri.css">
<style>
html, body, #mapDiv {
height: 100%;
margin: 0;
padding: 0;
</style>
<script>
var dojoConfig = {
parseOnLoad: true
</script>
<script>
var map;
var mis_rec = [];
var gis_rec = [];
point, pointData;
"dojo/dom",
"dojo/on",
"dojo/dom-class",
"esri/config",
"dojo/_base/lang",
"esri/request",
"esri/SpatialReference",
"esri/symbols/PictureMarkerSymbol",
"esri/graphic",
"dojo/domReady!"
function(Map, ArcGISDynamicMapServiceLayer,
ImageParameters, InfoTemplate, dom,
on, domClass, esriConfig,
esriRequestlang, esriRequest, SpatialReference, Point, PictureMarkerSymbol,
Graphic, GraphicsLayer) {
//esriConfig.defaults.io.corsEnabledServers.push("ncog.gov.in");
basemap: "topo", //For full list of pre-defined basemaps, navigate to http://arcg.is/1JVo6Wd
center: [75.0444, 15.3563], // longitude, latitude
zoom: 5
var dynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer("http://10.1.31.13/arcgis/rest/services/Thematic_Atlas/DVA/MapServer", {
"opacity": 1,
"imageParameters": imageParameters
map.addLayers([dynamicMapServiceLayer, polygraphlayer]);
dojo.connect(map, "onLoad", _ajaxcall);
_ajaxcall();
$.ajax({
type: 'GET',
dataType: 'json',
crossDomain: true,
success: function(dat) {
gis_mis1(dat);
error: function(err) {
//clearGraphics();
var rec = mis_rec[i];
if (rec.lon && rec.lat) {
var pt = new Point(Number(mis_rec[i].lon), Number(mis_rec[i].lat), new SpatialReference({
wkid: 4326
var markersymbol = new PictureMarkerSymbol("https://js.arcgis.com/3.15/esri/dijit/images/Directions/greenPoint.png", 21, 29);
var attr = mis_rec[i];
var content = '<table>';
map.addLayer(gl);
</script>
</head>
<body>
<div id="mapDiv"></div>
</body>
</html>
Anuj,
<!DOCTYPE html>
<html>
<head>
<style>
height: 100%;
margin: 0;
padding: 0;
</style>
<script>
var dojoConfig = {
parseOnLoad: true
</script>
<script>
var map;
var mis_rec = [];
var gis_rec = [];
point, pointData;
"dojo/dom",
"dojo/on",
"dojo/dom-class",
"esri/config",
"dojo/_base/lang",
"esri/request",
"esri/graphic",
"dojo/domReady!"
zoom: 5
"opacity": 1,
_ajaxcall();
$.ajax({
type: 'GET',
dataType: 'json',
crossDomain: true,
gis_mis1(dat);
//clearGraphics();
wkid: 4326
map.addLayer(gl);
</script>
</head>
<body>
</body>
</html>
Robert,
I have an issue that how to remove this graphic from map on checkbox event ,
it try to map.graphics.clear() function but it's won't work.
