jsapiv3.1, "dojo" undefined?
860
08-15-2012 10:36 PM
gaolei
when I use
<script type="text/javascript" src="http://pc01/arcgis_js_api/library/3.1/jsapicompact"></script>
it says "dojo undefined".
but if I use
<script type="text/javascript" src="http://pc01/arcgis_js_api/library/3.1/jsapicompact/js/dojo/dojo/dojo.js"></script>
it's OK
Are there any differents between them?
__Rich_
when I use
but if I use
it's OK
Have you set up the default document for the jsapicompact directory? (e.g. the ESRI-supplied default.ashx is fine if you're using IIS)
