JSAPI UniqueValueRenderer with FeatureLayer and Source (not URL) Work?
1460
03-18-2022 10:31 AM
rbossio
I'm building a FeatureLayer dynamically on the UI. Basically, I create a new FeatureLayer and set the Source field. Using basic renderer, the layer displays correctly (simple-fill symbol with specific color). But, if I use UniqueValueRenderer no features render. I can verify that I'm referencing the correct field in the UniqueValueInfo. My first questions is, does the UniqueValueRenderer work with a FeatureLayer built entirely on the client using "Source" field, rather than referencing an online layer? If so, are there any examples of that (I can't find any). Thanks.
Tags (1)
KristianEkenes
Yes, this works. Do you have a link to your app so I can take a look at where it's failing? Here's an example of this working: https://codepen.io/kekenes/pen/JjMXKVa?editors=100
rbossio
Thanks Kristian - unfortunately, the app is internal only. I think I have a bigger problem in that I can't get a simple UniqueValueRender to work from esri tutorials. I'm wondering if I'm missing something. Link below defines the renderer, adds a UniqueValueInfo, creates the FeatureLayer with the renderer, and adds to the map. If I display the hosted feature layer without specifying a renderer, I can see all the features. When I add the renderer to the feature layer, no features display. Am I missing some setting maybe?
NOTE: Link to feature in codepen is a public feauture layer
https://codepen.io/rjbtampa/pen/PoEGPVL
Sample Feature Data:
JoelBennett
MVP Regular Contributor
If the data you're using is point data, as in your example, you should use SimpleMarkerSymbol instead, which is intended for rendering points.  SimpleFillSymbol, on the other hand, is intended for rendering polygons.
KristianEkenes
Yep. Joel is correct. If you use simple marker symbols, it works: https://codepen.io/kekenes/pen/popegLv?editors=1000
This can be a little confusing. You can use SimpleFillSymbol and SimpleMarkerSymbol on polygon layers, but only SimpleMarkerSymbol for point layers.
