JSAPI 4.0 Levels of Detail - how to set?
2055
08-04-2016 10:39 AM
DavidColey
MVP Frequent Contributor
Hi -
I'm trying to figure out how to set the levels of detail at 4.0 to control zoom extents.  Is there a way at this time to set at the map or mapview class?
Thanks
David
thejuskambi
thejuskambi
Are you looking for something like LOD in constraints
MapView | API Reference | ArcGIS API for JavaScript 4.0
DavidColey
Yes Thejus, that's exactly it, I should have been more clear.  I've got my lods var set in an array:
var myLods = [{"level" : 0, "resolution" : 4891.96981024998, "scale" : 18489297.737236},
        {"level" : 1, "resolution" : 2445.98490512499, "scale" : 9244648.868618} . . . ];
then set my view constraints:
view.constraints = {
  effectiveLODs : myLods
can't see seem to get past an accessor type error
DavidColey
I got it, thanks for the help:
  lods : myLods
