JSAPI 3.13 released March 6, 2015
5747
7
03-06-2015 10:43 PM
BjornSvensson
Esri Alum
Version 3.13 of the ArcGIS API for JavaScript has been released. Read about it in the blog http://blogs.esri.com/esri/arcgis/2015/03/06/arcgis-api-for-javascript-version-3-13-released/ or check out the details in the Whats New https://developers.arcgis.com/javascript/jshelp/whats_new.html
SteveCole
Honored Contributor
Very cool to have operations like buffer on the client side, thank you!
I'm also interested in the nearestVertices method, although I would have liked to have seen a simple "along" method to return a location a specified distance from the start/end of a line. NearestVertices sounds similar but I think there is a difference between the two concepts.
ChrisSmith7
Honored Contributor
It's really exciting having the ability to geoprocess client-side!
Wanted to give you guys a heads-up - I noticed the legends are now broken with v3.13 when joining JSON data (just reads as "Creating Legend..."):
http://developers.arcgis.com/javascript/samples/data_gas_price
Do you guys have any fixes/workarounds available? I tried a few different things, but was unsuccessful in finding a resolution.
Thank you!
TonyGeorges1
It looks great !
I try to download the api for working locally, but there is only 3.12 and lower on SDK Downloads | ArcGIS for Developers
When do you planned to make available the new API for download ?
Thank you,
Tony
JeffPace
Was great meeting you at the Dev Conference.  When will 3.13 be available for download??
JeffPace
Still waiting on that 3.13 release.  It fixes a bug we desperately need to patch
Kelly HutchinsBjorn Svensson
BjornSvensson
Esri Alum
Version 3.13 is now available for download - https://developers.arcgis.com/en/downloads/
khairulamri
Hi Bjorn,
Thanks for the info, that is what I waiting for.
