JSAPI 1.6 and IE error
978
04-27-2010 08:14 AM
GabiVoicu
I'm getting an exclamation mark - error message with IE browser - whener running new updated jsapi 1.6 with our map link here
http://maps.collincountytx.gov/mainv16.html
It points to dojo toolkit and Firefox is ok.
Thank you
KellyHutchins
Esri Notable Contributor
You may be running into the issue described in the following forum thread. This is a problem only in IE, here's the bug number and the link below has a patch you can apply:
NIM054763: When running an application that uses the Dojo Border Container and Content Panes for layout an invalid argument error occurs when the browser is resized. This only happens in IE.
http://forums.esri.com/Thread.asp?c=158&f=2396&t=301691&mc=5
