JS API: reorder layers with a tiled reference layer
4648
07-31-2015 01:21 PM
AndyBell4
I'm trying to add a reference layer from a tiled map service to be above a polygon feature layer with the ArcGIS JavaScript API. I tried using map.reorderLayer() to change the layer order but the reference layer is still showing up below the polygons.
// Reference overlay
var referenceLayer = new Tiled("http://hydrology.esri.com/arcgis/rest/services/WorldHydroReferenceOverlay/MapServer");
//add the reference layer
map.addLayer(referenceLayer);
//Change layer order
map.reorderLayer(featureLayer, 0);
map.reorderLayer(referenceLayer, 1);
Example: http://bl.ocks.org/andybell/74fb4a1de74898126fbe
What is the best way to force the reference overlay to be the topmost layer?
KenBuja
MVP Esteemed Contributor
The issue here is that you're using a FeatureLayer. That inherits from a GraphicLayer, which is always shown on top of tiled or dynamic layers.
KenBuja
RobertScheitlin__GISP
Andy,
   The issue you are seeing id that the FeatureLayer that you are adding will always draw on top of other layers that are not FeatureLayers or that inherit from GraphicsLayer. This is a known limitation of the 3.x JS API and is something that will be reworked in the 4.x JS API.
