JS API 4.17: Direction highlited not cleaned up
1450
10-13-2020 02:27 AM
NicolasGIS
Honored Contributor
Hello,
Just noticed a small bug with JS API 4.17 (but also in previous version): when a direction is highlited after having clicked on it in the widget, it is not cleaned up after reseting the route or destroying the widget:
Direction highlited      Highlite remains
You can easily reproduce it on this sample:
ArcGIS API for JavaScript Sandbox
Thanks for listening !
/cc Noah Sager
Noah-Sager
Hi Nicolas GIS‌, thank you for reporting this issue. I can reproduce it as well. Will investigate and update this thread when we have an update to share.
Noah-Sager
As a follow-up, if you use the `Clear route` option, does it properly clear the route and segments properly?
