jQuery Layout Map issue.
1993
10-30-2012 08:21 AM
AndrewDavis
I've got a jQuery Nested Layout which I am trying to incorporate an ESRI map into.
Similar to: http://layout.jquery-dev.net/demos/nested.html
I am getting odd behavior from the wms.
[ATTACH=CONFIG]18845[/ATTACH]
Has anyone used jQuery and a map in a layout?
Andy...
JeffJacobson
Did you include a reference to the esri.css file?  This requirement was added to the JS API fairly recently, and if you omit it the results look like what is show in your screenshot.
AndrewDavis
I checked, and yes I have a ref to the esri.css file..
Andy.
derekswingley1
I would double-check that you've included a <link> tag to bring in esri.css and make sure it's being loaded via your browser's dev tools. That seems to be the most likely explanation for the issue you're seeing.
I put together a version of their "nested" sample and it works. It's attached as a .zip file.
Edit:  You also said "WMS" but the screen shot looks like it's showing the standard ArcGIS Online Streets basemap. Did you mean tiled service? I used the streets tiled service in my example.
AndrewDavis
Yes,
Thank you for your help.
I appreciate the forums quite a bit..
Andy
