Jquery icon disappear- ArcGIS Javascript API
5727
09-12-2014 03:50 AM
FaisalBukhari
Hi
I have strange situation i use  JQuery library with ArcGIS Javascript API   both local  All files (image folder + CSS + JS) and on server as below
the functionality is working fine
The problem is  i can see the JQuery  Icon  (related button and Combobox)    while page is loading but   page is fully loaded my icon is disappear
Thanks in advance.
Tags (1)
JonathanUihlein
Need more code.
Can you create a sample of your issue using jsfiddle so I can take a look?
Thanks!
FaisalBukhari
dear Jonathan
I run the code  in  jsfiddle  the code working pretty fine.i can see my icon
but on local machine my problem is still persist.
i am using Aptana web IDE
Thanks
JonathanUihlein
I need to see the jsfiddle to be able to help
PatrickThorsell
I am having same issue. Button and Dropdown appear for 1/2 second then disappear once page loads. Were you able to figure this out?
ChrisSergent
You might want to do two things for others Devs to better help you on here: post a copy on Create a new fiddle - JSFiddle  and since you said your code is working on there, it may help to see what you are doing. You can download  CamStudio a free recording tool, and then record your screen so other devs can see what is happening. Are you receiving any errrors. Press control + shift + J and click on console when your app is running in Google Chrome. If there are any errors, copy and paste them to this thread.
