jQuery grid select multiple rows
3286
04-23-2025 10:21 AM
Mr_Kirkwood
How would you select multiple rows? I have an array of data that i select from a map (Several different OBJECTIDS). I would like to be able to select the rows in the grid that have the same OBJECTIDS.
Here are a few links of the example code i am trying to use to select multiple rows:
https://www.jqwidgets.com/community/topic/select-a-row-with-value-instead-of-index/
https://jsfiddle.net/jqwidgets/FQxrf/
Here is my code:
//using a button to create the row selection
$(“#selectRowByValue”).on(‘click’, function () {
    var rows = $(‘#roomUseTable’).jqxGrid(‘getrows’);
    console.log(rowsCount)
    var myroomEditData = [];
    for (var i = 0; i < rows.length; i++) {
        const valueObjectID = $(‘#roomUseTable’).jqxGrid(‘getcellvalue’, i, “OBJECTID”);
        console.log(“roomsAssignedData Data from the map”)
        console.log(roomsAssignedData)
        myroomEditData.push(
            valueObjectID
        console.log(“myroomEditData”)
        console.log(myroomEditData)
        //comparing the data from the map to the data in the grid
        const intersection = myroomEditData.filter(element => roomsAssignedData.includes(element));
        console.log(intersection)
This gives me the OBJECTIDs in the grid. My example shows 3 rows and it gives me back the three rows OBJECTIDs (myroomEditData). When I select the data in the map it gives me the OBJECTIDs of the data that it selected (roomsAssignedData) from a different piece of code.
How would I pass more than one value to get it to select (value == "Ikura”)? The values are in my array (myroomEditData).  I tried (value ==  myroomEditData) but it only selects the 1st row even if that’s not the data selected in the map.
Edvinas_S
Your question is off-topic, but I'll help.
First, you need to enable selection of multiple rows when you define your grid.
$("#roomUseTable").jqxGrid({
    selectionmode: 'multiplerows',
And this is the select function, assuming that roomsAssignedData is an array.
$("#selectRowByValue").on("click", function () {
    // get all rows
    var rows = $("#roomUseTable").jqxGrid("getrows");
        // if value of field 'OBJECTID' is in roomsAssignedData array
        if (roomsAssignedData.includes(rows[i].OBJECTID)) {
            // add row to selection
            $('#roomUseTable').jqxGrid('selectrow', i);
Noah-Sager
Hi @Mr_Kirkwood, thanks for posting your question here. Are you trying to use a jQuery grid with the ArcGIS Maps SDK for JavaScript? If so, you might want to check-out our FeatureTable:
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-FeatureTable.html
https://developers.arcgis.com/javascript/latest/sample-code/widgets-featuretable-row-highlights/
Mr_Kirkwood
I am using the Query grid with the ArcGIS Maps SDK for JavaScript, and it works great. The grid has more functionality like drop down quick viewing of the data (attachment SMV_B). I can set up custom filtering and querying (attachment SMV_C).  I can also set up the grid to zoom to the data with an onclick and customize the export to excel and other formats.
I have used the FeatureTable and could not get the custom ability that I get from the grid. I will look at the examples you sent.
Thanks for the information.
p.s. I am using the ArcGIS Maps SDK for JavaScript for most of my application.
Edvinas_S
    // get all rows
Mr_Kirkwood
Wow, that helps me out tremendously! I appreciate the help. Sorry it was off topic. I have posted in other forums to no avail.
Thank you!
