Hi all, I am using JQuery drag function to allow users to drag their panels around. It works great but I am experiencing some issues when dragged out of the document to the right. It seems like it is causing a white margin to appear to the right of the window. Any idea? jsbin.
Solved! Go to Solution.
Look into the properties available to the draggable functionality.
You have: $('.LayerDrag').draggable({});
Add constrainment like this: $('.LayerDrag').draggable({ constrainment: '#divName' });
'#divName' would be the container you want your draggable to stay within, like, your DOM element that you put your map in.
Note: For your QueryDrag element, you only have "draggable()". You'd need the {} to add draggable properties, like above.
