Joining Multiple Polylines
2753
01-19-2011 04:50 PM
MichaelLove
I'm using the esri google maps extension api...
I have a esri.arcgis.gmaps.FeatureSet() (of type esriPolyline) containing an array of features (esri.arcgis.gmaps.Feature()).
Is there a simple way to create a single GPolyline from the array of features?
or, since feature.geometry is a GPolyline, I guess I am asking is there a simple way to create a single GPolyline by joining/merging multiple GPolylines?
FYI - I also asked this question here
HemingZhu
There are a couple of ways to achieve this. 1. using geometry service's union(geometries, callback?, errback?) method. 2. using Polyline's addPath(points or path or pointJson) method.
MichaelLove
Hi Heming,
thanks for the prompt reply.
With regards to your responses...
1. I had a look at the Geometry service rest api page (/arcgis/rest/services/Geometry/GeometryServer), I don't appear to have a "Union" function available, only "Project",   "Simplify", "Buffer", "Areas And Lengths", "Lengths"
2. I'm using the arcgis Google Maps api, the esri.geometry.Polyline.addPath method (or class) is not available in the .js library (http://serverapi.arcgisonline.com/jsapi/gmaps/?v=1.6). Also, the arcgis js library uses the V2 google maps api (now deprecated)), so the google maps V3 methods are not available either.
thanks again for the assistance,
cheers,
Michael
