Joined Field in ClassBreaksRenderer
4054
7
03-14-2016 04:20 PM
by Anonymous User
Not applicable
Hello - I have a ClassBreaksRenderer that's failing when I use a joined field for the attributes. The joined field name has periods in it, e.g.  'database.dbo.testField'. I don't see anything about this renderer not working on joined data -- can it not handle the field name?
Thanks!
var testCBR = new ClassBreaksRenderer(lmpPoint0, "database.dbo.testField");
        testCBR.addBreak({
            maxValue : 10,
            minValue : -50,
            symbol : lmpPoint1
        testCBR.addBreak({
            maxValue : 20,
            minValue : 10.01,
            symbol : lmpPoint2
        testCBR.addBreak({
            maxValue : 21,
            minValue : 20.01,
            symbol : lmpPoint3
        testCBR.addBreak({
            maxValue : 22,
            minValue : 21.01,
            symbol : lmpPoint4
        testCBR.addBreak({
            maxValue : 23,
            minValue : 22.01,
            symbol : lmpPoint5
        testCBR.addBreak({
            maxValue : 30,
            minValue : 23.01,
            symbol : lmpPoint6
var testCBROption= new LayerDrawingOptions(;
testCBROption.renderer = testCBR;
var lmpOptions = [];
lmpOptions[2] = testCBROption;
var test = new ArcGISDynamicMapServiceLayer("https://etc.etc.etc", {
  showAttribution : false,
  visible : true
test.on('load', function() {
  test.setLayerDrawingOptions(lmpOptions);
RobertScheitlin__GISP
Sarah,
  Can I see the code you are using to add that field to the ClassBreaksRenderer?
by Anonymous User
Not applicable
Hi Robert - I updated my question with code. I cannot post the whole application but that's the gist of it
Sarah,
  This is what I used on a joined field and it worked fine:
var renderer = new ClassBreaksRenderer(symbol, "Parcels3.PRICE_SOURCE");
        renderer.defaultSymbol = new SimpleFillSymbol().setColor(new Color([255, 255, 255, 0.5]));
        renderer.addBreak(0, 1, new SimpleFillSymbol().setColor(new Color([56, 168, 0, 0.5])));
        renderer.addBreak(2, 2.99, new SimpleFillSymbol().setColor(new Color([139, 209, 0, 0.5])));
        renderer.addBreak(3, 3.99, new SimpleFillSymbol().setColor(new Color([255, 255, 0, 0.5])));
        renderer.addBreak(4, 4.99, new SimpleFillSymbol().setColor(new Color([255, 128, 0, 0.5])));
        renderer.addBreak(5, Infinity, new SimpleFillSymbol().setColor(new Color([255, 0, 0, 0.5])));
        var infoTemplate = new InfoTemplate("${Parcels3.NAME}", "${*}");
by Anonymous User
Not applicable
I tried changing the format to match what you used, no go. The field works fine for definition expressions and info templates. In fact, although the data doesn't display if I click randomly I eventually hit something and get a pop-up with the feature's data. It's there, just not drawing.
The issue isn't the symbols because they work fine on other layers, and the renderer works on other layers as well.
The only difference I see with your example is that my layer is from an SDE and there are two periods...
Sarah,
  Is this a join or a view in the SDE?
by Anonymous User
Not applicable
Join in the ArcMap document that is published as a service
Sorry to say it sounds like a tech support call then.
