JavaScript Web Optimizer error
2979
07-14-2014 10:50 AM
JeffPace
I am trying to use the JavaScript Web Optimizer, and i keep getting this error when i try to scan my website
        <script>
            var hostPath = window.location.pathname.replace(/\/[^/]+$/, "");
            dojoConfig = {
                parseOnLoad: false,
                        async:true,
                baseUrl: '/arcgis_js_api/library/3.9/arcgis/js/dojo/dojo',
                packages: [{name: 'org', location: hostPath + '/..' + '/mobile/org'},
                    {name: 'agsjs', location: hostPath + '/..' + '/mobile/agsjs'},
                    {name: 'com', location: hostPath + '/..' + '/js/com'},
                    {name: 'utilities', location: hostPath + '/..' + '/mobile/utilities'}
                isDebug: false,
                usePlainJson: false
        </script>
        <script src="/arcgis_js_api/library/3.9/arcgis/?v=3.9"></script>
TyroneBiggums
Put line 16 above line 1, maybe? I think you'll need to reference the API, on line 16, before dojoConfig. I have the API referenced as my first script element, and I have a separate config.js script element near about the last script referenced.
Might not do anything for you, but worth a try?
