Javascript Search Widget (searchWidget.sources.push(sources))
4546
7
05-23-2016 04:49 AM
SachinTiwari
     Just would like to confirm that, the search widget is pushing search layer at right level or not ?
because when i try to push a source then it gets added in wrong heirchical level.
var sources = [ { declare only one source } ]
// Add to source(s)
var searchWidget = new Search();
searchWidget.sources.push(sources);
//new source
searchWidget.startup();
Then it shows heirchy like
items
     [0]
     [1]
          [0] and here is my source (underneath of [1][0])
I believe my source should be at [1] level of heirchy.
Please correct me if i am missing anything.
FC_Basson
You are adding an array and not a source object.  Just remove the square brackets from your sources variable declaration.
SachinTiwari
SachinTiwari
if the heirchical level is correct then why i m not able to search on added (pushed) sources, whereas when i add the same source at the constructor level of Search() widget then it works perfectly.
FC_Basson
SachinTiwari
Thanks for the solution. (Heirchical level is solved by your response but search issue is still remains)
But the issue remains the same, when i tried to push a source then it won't search on pushed source. and when i assign the same code in the constructor of search() widget then it searches perfectly. I think i am lacking somewhere, let me check once again. or if you have any other clue on that ?
FC_Basson
I've constructed my own search sources like this in the past:
sources = searchWidget.get("sources");
sources.push(newsourceobject); //push for adding at the end of the list and unshift to add at the front of the list
searchWidget.set("sources", sources);
SachinTiwari
other way around 🙂
FC_Basson
You mean the push/unshift? I'm pretty sure. JavaScript Array unshift() Method
