Javascript not accessing the view?
1077
09-08-2020 11:38 AM
SteveBroyles
My app uses simple javascript to control basic map location, zoom, etc. This works fine with several map service providers but I'm having trouble with ArcGIS.  It seems I can't access the view.  I'm wondering if the 'require' is somehow involved or if it's some other a basic error. The code is loaded in a browser control but is unresponsive.  Simply double clicking the html file displays the starting map as expected.
   <link rel="stylesheet" href="https://js.arcgis.com/4.16/esri/themes/light/main.css" />
    <script src="https://js.arcgis.com/4.16/"></script>
    <script>
        require(["esri/Map", "esri/views/MapView"], function (Map, MapView) {
            var zoomlevel = 14;
            var ready = false;
            var map = new Map({
                basemap: "topo"
            var view = new MapView({
                container: "viewDiv", // Reference to the view div created below
                map: map, // Reference to the map object created before the view
                zoom: 14, // Sets zoom level based on level of detail
                center: [-78.25, 37.375], // Sets center point of view using longitude,latitude
                ui: { components: ["attribution"] } // exclude zoom widget from default ui
            view.when(function () {
                // All the resources in the MapView and the map have loaded. Now execute additional processes
                ready = true;
            }, function (error) {
                // Error handling
// Unresponsive methods
            function IsReady() {
                return ready;
            function Up(ctrlkey) {
                if (zoomlevel > 9) zoomlevel = zoomlevel - 1; /* 9 to 18 */
                if (ctrlkey) {
                view.zoom = zoomlevel;
// Down
            function GetRight() {
                return view.extent.xmax;
//Left, etc.
            function SnapTo(lat, lon) {
                view.center = [lon, lat];
</script>
RobertScheitlin__GISP
Steve,
   I see nothing wrong in the code portion you have provided. Can you provide a more complete sample the demonstrates your issue?
