javascript feature layer render issue
2346
11-07-2011 07:52 AM
JaredAllen
i'm adding a feature layer service via the js api. i'm getting the following errors/warnings...
Unexpected value NaN parsing x attribute.
Unexpected value NaN parsing y attribute.
Unexpected value matrix(1.00000000,0.00000000,0.00000000,1.00000000,NaN,NaN) parsing transform attribute.
the features from this service are being rendered as expected, with the addition of a stacked set of these features in the far upper-left of the map view port too!
the following is the code which i'm using to add the feature service layers...
var serviceRequestLayerURL = "http://arcgisserver.northwind-inc.com/ArcGIS/rest/services/itd_service/MapServer/0";
var serviceRequestmobileLayerURL = "http://arcgisserver.northwind-inc.com/ArcGIS/rest/services/itd_service/MapServer/0";
var serviceRequestLayer = new esri.layers.FeatureLayer(isBorwser ? serviceRequestLayerURL : serviceRequestmobileLayerURL, {
                mode: esri.layers.FeatureLayer.MODE_SNAPSHOT,
                outFields: ["*"],
                displayOnPan: true
            map.addLayer(serviceRequestLayer);
            var serviceRequestCommentsLayer = new esri.layers.FeatureLayer(serviceRequestCommentsLayerURL, {
                mode: esri.layers.FeatureLayer.MODE_SELECTION,
                outFields: ["*"],
                displayOnPan: false
            map.addLayer(serviceRequestCommentsLayer);
Charles__Jamie_Phillips
I just ran into the same issue.
JasonFoster
Did anyone ever figure out what is happening. It occurs two or three times out of four for me.
JianfengZhao
It occurred to me a number of times. It usually happens at the initial call of the map.setExtent in my application. Did anyone figure out what is happening or how to debug it?
SunilPalkar
I am getting an same error..
Any idea?? waiting for reply from senior members  : |
SunilPalkar
Hello All,
My issue was resolved.
Reason : I have few blank records + special character in database..
After cleaning all everything is up and running..
Esri forums are simply great... like support !! : ):)
