Javascript error: function not defined????
65210
12
08-26-2013 08:24 AM
by Anonymous User
Not applicable
however it IS defined....here:
require(["dojo/dom",
        "dojo/_base/array",
        "dojo/_base/Color",
        "dojo/parser",
function(dom, array, Color, parser, Map, esriLang, Graphic, FeatureLayer, InfoTemplate, GraphicsLayer, SimpleRenderer, Point, FeatureSet,
             ClosestFacilityTask, ClosestFacilityParameters, SimpleMarkerSymbol, SimpleLineSymbol){
      var map, incidentsGraphicsLayer, routeGraphicLayer, closestFacilityTask, params, facilitiesFeatureLayer, handler;
    function myFunction() {
      alert("Do Something");
<body class="claro">
<div> <button onClick="myFunction()">Pick Point</button></div>
</body>
</html>
BenFousek
Sorry...use dijit.byId because it's a widget.
dijit.byId('toolBuffer').get('value');
BenFousek
onClick will not work on html elemets. You want onclick.
<button onclick="myFunction()">Pick Point</button>
onClick is a dojo event for widgets like dijit/form/Button.
<div data-dojo-type="dijit/form/Button" data-dojo-props="label: 'Pick Point', onClick: function() { myFucntion() }"></div>
derekswingley1
myFunction is not available in the global scope, which is where it needs to be if you want it to run via an onclick attribute of an html element. You could create myFunction as a global by putting:
var myFunciton;
at the root of your script tag and then:
myFunction = function() {
But that's the wrong way to do this. In general, it's bad practice to add onclick handlers via markup. Mixing JS and markup is not a good habit to develop. Instead, get a reference to your element (could use dojo/dom.byId or dojo/query) and bind a click handler with dojo/on.
by Anonymous User
Not applicable
Thanks for the quick reply, Ben. However that did not remedy the issue. Same error message.
Thanks!
rGIbson
BenFousek
Look at Derek's post.  I missed the fact myFunction() wasn't also globally available.
by Anonymous User
Not applicable
Good tip....thanks, Derek.
So something like this did the trick perfectly.
registry.byId("trace").on("click", fireTrace);
function fireTrace() {
  doSomething;
<button id="trace" data-dojo-type="dijit/form/Button">Pick Point</button>
Thanks again, Derek and Ben for your quick replies and help.
rGibson
derekswingley1
Nice, glad we could help!
JeffPace
I know you already have an answer, but I struggled with this last week and found an even easier solution, adding one line to your code
//define a variable for your function
var myFunction = function myFunction() {
//make function global
lang.setObject("myFunction", myFunction);
by Anonymous User
Not applicable
However now I'm curious why this returns "undefined"
registry.byId("toolBuffer").on("click", fireBuffer);
function fireBuffer() {
  alert(dom.byId('toolBuffer').value);
<input id="toolBuffer" data-dojo-type="dijit/form/Button" data-dojo-props="iconClass:'findNear', showLabel: false" value="buff"></button>
BenFousek
Try this:
Add value as property:
[HTML]<input id="toolBuffer" data-dojo-type="dijit/form/Button" data-dojo-props="iconClass:'findNear', showLabel: false, value: 'buff'"></button>[/HTML]
Use .get('value') to get the value:
dom.byId('toolBuffer').get('value');
