Javascript dojox/form/CheckedMultiSelect
6567
13
07-23-2014 06:03 AM
deleted-user-yA_w_FC9FKe5
I am creating a simple application where I am going to have a lot of different dropdown type boxes.  I really like the dojox/form/CheckedMultiSelect.  However, I am having an issue when trying to load the contents of it from a .js file.  I've attached my test file and the js file.  It seems to be working okay in IE but is not working in Safari or Chrome.  I have no idea why?  As you can see from my code the dojox/form/CheckedMultiSelect seems to work in Safari and Chrome.  It only seems to be an issue when I am trying to populate it via the .js code.
Any help would be very much appreciated as this is very frustrating and I have been working on this for a few days now.
Michael
Thanks Ken.  I know about AMD and only used the legacy because it was just the quickest way to get the code out there for you guys to view.  I looked at the bookmark example but because it is a widget vs a CheckedMultiSelect box I'm not sure how to equate one to the other.  Your eample shows me how to do it all in the one html file but I really want to seperate out the values just like the bookmarks.  I have a feeling it would take you like 5 minutes to whip up an example like this.  You seem to be a guru at this stuff.
DavidColey
MVP Frequent Contributor
I know this is a bit late in the game and hopefully not too obvious, but by setting up your dojoConfig var within a script tag of your html and setting up your packages, async and parseOnLOad options we've never had any issues:
    <script>
      var path_location = location.pathname.replace(/\/[^/]+$/, "");
      var dojoConfig = {
      packages : [{name: "agsjs", location: path_location + "/agsjs"},
      {name: "js", location: path_location + "/js"}],
        async : true,
        parseOnLoad : true
    </script>
David
Thanks David.  I tried this but it did not work.  I really wish it were that easy.
For now I have removed all of the these and replaced them with dijit.form.MultiSelect.  It is uglier but they seem to work fine.
Thanks to all who tried to help.
RobertScheitlin__GISP
Michael,
   Strange, Lucas's example worked for me in both FirsFox 31 and Chrome 36
