Javascript CORS
2238
04-14-2020 09:23 AM
HamzaBoudemia
Hi all,
I will try to be quick.
I have an ASP.Net application deployed on IIS.
This application use ESRI Javascript 4.14 API to access to a feature layer in ArcGIS Portal.
So far, so good.
In all browsers (dev machines, integration machines, developers machines...), it works fine.
But in one machine, we have CORS error. when I try to debug my Javascript, in the console, I can see following message (translated from french error message) :
Blocking of a multi-origin request (Cross-Origin Request): the "Same Origin" policy does not allow consulting the remote resource located on URLOfMyFeatureServer/FeatureServer/0.
Reason: CORS request failed.
Has any one ever encountered this problem ?
Thank you in advance
HamzaBoudemia
Hi Victor,
Can you please tell me which server should support CORS ? IIS server (hosting the ASP.Net application) or ArcGIS Portal Server (hosting the layers) ?
Noah-Sager
Another option is to try the trustedServers property:
esriConfig.request.trustedServers - API Reference
HamzaBoudemia
Thank you for the answer. I think it will be more convenient If this solution works. I will try it today.
HamzaBoudemia
One more question : can I reproduce this behavior on my machine ? (CORS ERROR).
Thanks in advance
