Javascript api
2226
07-25-2014 12:34 PM
ChrisHolmes
Hello, I am new to working with the api so have started with the "Build your first application" https://developers.arcgis.com/javascript/jstutorials/intro_firstmap.html
I think I have all of the text correct, but what I end up with is the following in the browser:
var map; function init() { map = new esri.Map("mapDiv", { center: [-56.049, 38.485], zoom: 3, basemap: "streets" }); } dojo.ready(init);
Here is a copy of my file:
<!DOCTYPE html>
<html>
  <head>
  <title>Create a Map</title>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
  <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
  <script src="http://js.arcgis.com/3.10/"></script>
  <style>
   html, body, #mapDiv {
    padding: 0;
    margin: 0;
    height: 100%;
  </style>
  <script>
   dojo.require("esri.map");
   function init() {
    var map = new esri.Map("mapDiv", {
    zoom: 3,
    basemap: "streets"
   dojo.ready(init);
  </script>
</head>
<body class="claro">
  <div id="mapDiv"></div>
</body>
</html>
Any ideas as to what I am missing are appreciated. Thanks!
Tags (1)
TimWitt2
Chris,
you should start using the following code (AMD), the code you are using is legacy, which will soon " go away".
<!DOCTYPE html>
<html>
<head>
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <style>
    html, body, #mapDiv{
      padding: 0;
      margin: 0;
      height: 100%;
  </style>
  <script>
    var map;
    require(["esri/map", "dojo/domReady!"], function(Map) {
      map = new Map("mapDiv", {
        zoom: 3,
        basemap: "streets"
  </script>
</head>
</body>
</html>
Hope this helps!
Tim
TimWitt2
Chris,
<!DOCTYPE html>
<html>
<head>
  <style>
      padding: 0;
      margin: 0;
      height: 100%;
  </style>
  <script>
    var map;
        zoom: 3,
        basemap: "streets"
  </script>
</head>
</body>
</html>
Hope this helps!
Tim
ChrisHolmes
Thanks for the help Tim!
BjornSvensson
Esri Alum
ChrisHolmes
Thanks for the link Bjorn!
