Javascript API Developer Environment Setup
936
01-29-2014 06:15 AM
MichaelVolz
Esteemed Contributor
To All Javascript API Developers:
What ESRI software needs to be installed on a development computer to create a Javascript API web application and/or services?
When creating .NET SDK applications, I needed ArcGIS Desktop and the .NET SDK installed on the development.  As such I'm looking to determine the software requirements for Javascript development.
Any help or hints are greatly appreciated.
ShaningYu
Honored Contributor
Actually you don't need any ESRI software since you only need to use some services.  From https://developers.arcgis.com/javascript/jstutorials/intro_agstemplate_amd.html, you should get all of the details.  You may use VS or NotePad, NotePad+or other editor to program your file.  Good luck.
nicogis
MVP Alum
