javascript api 3.13 geometryEngine.geodesicBuffer error
5508
04-07-2015 08:07 AM
BryanWestphal
Im trying to use the new geometryEngine.geodesicBuffer.  when passing in my polygon geometry, the api is throwing the following error. (Uncaught TypeError: Cannot read property 'dd' of null)  geomtryEngine.js: 519
I believe this is a bug in the new client side geometry engine.
I'm using Web Mercator projection (wkid 102100).
            var SelectGraphicsLayer = map.getLayer("SelectGraphicsLayer");
            var _geometry;
            var _geometries = [];
            for (var i = 0; i < SelectGraphicsLayer.graphics.length; i++) {
                _geometries.push(SelectGraphicsLayer.graphics.geometry);
            if (_geometries.length > 1) {
                _geometry = GeometryEngine.union(_geometries);
            else {
                _geometry = _geometries[0];
            //var buffer = GeometryEngine.buffer(_geometry, 330, Units.FEET, true); //THIS ONE WORKS
            var buffer = GeometryEngine.geodesicBuffer(_geometry, 330, Units.FEET, true);  // THIS ONE DOES NOT
BjornSvensson
Esri Alum
The geodesicBuffer takes a number for the units.  Try specify 9002 as the third argument.  See https://developers.arcgis.com/javascript/jsapi/esri.geometry.geometryengine-amd.html#geodesicbuffer which has a link to esriSRUnitType Constants.
While not technically a bug, this syntax is likely to change for the next version.
BjornSvensson
Esri Alum
