(javascript 3.23 API) toggle off sublayers when the main layer is toggled off
2134
6
01-31-2018 07:08 AM
by Anonymous User
Not applicable
Using the layerlist widget (3.23 API) how can I cause all sublayers to be toggle off when the main layer is toggled off
RobertScheitlin__GISP
Randy,
  Unless I am missing something... When the parent layer is toggled off all its sublayers are toggled off as well.
I just tested this sample to be sure.
https://developers.arcgis.com/javascript/3/sandbox/sandbox.html?sample=widget_layerlist_basic
by Anonymous User
Not applicable
But when you turn the main layer off, the sublayers that were active remain
active. I need all of the subLayers to be deselected when the main is
toggled off
On Wed, Jan 31, 2018 at 11:29 AM, Robert Scheitlin, GISP <[email protected]>
Randy,
   That is not what I am seeing... If I toggle a parent layer off the the visibility of all sublayers are are turned off as well.
by Anonymous User
Not applicable
Yes...the visibility. but I need the sublayer checkboxes to be toggled off
as well. My code depends on the action of selecting the individual
checkboxes for the sublayers. subLayerIndex returns to null when the
mainlayer is reselected but the sublayer stays visible and the checkbox
remains selected. The user, in this case, would have to deselect the
sublayer and reselect it in order for the code to evaluate properly.
On Wed, Jan 31, 2018 at 11:45 AM, Robert Scheitlin, GISP <[email protected]>
Randy,
   My suggestion is that you reevaluate your workflow. When a parent checkbox is set to false the you get the layers sublayers and do you code logic on the fact that all the parent layers sublayers are now not visible and do not depend on the checkbox change event for the sub layers. I don't think you want to cause the checkbox to toggle on the sublayers as that mean the user would have to re-check the ones they want to be visible each time they un-check the parent and re-check the parent.
by Anonymous User
Not applicable
Robert,
Thanks but I am dealing with many image layers and sublayers and reading
pixel values via a mouse pointer. The pixel value must then be evaluated
using identifytask on the rest service layer relevant to the selected
image. I can see no way to identify the image on the map other than it
having been selected. If all sublayer image references are not nullified,
the user will not be sure which image layer is being evaluated. I have
explored a number of different approaches to this problem but I am unable
to conceive of another solution.
On Wed, Jan 31, 2018 at 12:25 PM, Robert Scheitlin, GISP <[email protected]>
