Issues with TextSymbols using Compact JS 3.8
895
01-22-2014 12:30 PM
GregoryDillon
I am seeing the following issues with TextSymbols in compact (mobile) JS 3.8.  In my case I'm mixing TextSymbols
and SimpleMarkerSymbols (points) in the same Graphicslayer.
With IE 9 Compatibility Mode -
      Only SimpleMarkerSymbols display.    There is also a latency in the when this layer initially displays.
With IE 11, Chrome, Safari (on iOS iPad2) -
      TextSymbols are shifted to the left from previous JS 3.7 or before.
After switching back to JS 3.7 compact the problem goes away.    I have not tested the non-compact version.
