Issues with buffering selected features/query task
10832
22
10-15-2014 08:02 AM
RyanSellman
I am trying to give users the ability to select features from a specific feature layer, buffer that selection and query another feature layer using the geometries from the buffer.  I want results from the first selection to be sent to one datagrid and results from the second query to be sent to a different datagrid.  I think I am really close - the way I have it set up now is the user can draw a box to select features (points in this case).  When the drawing ends, it select features within the drawn extent, performs a buffer at a set distance on those features, and uses the buffer extent to select features from a polygon layer.  This all works just fine however, the issue I am having is with the two datagrids.  For some reason, data from the first selection is being pushed to both datagrids.
Here is a bit of JS:
dojo.connect(map, "onLoad", function(map) {
    //initialize the toolbar
    toolBar2 = new esri.toolbars.Draw(map);
    dojo.connect(toolBar2, "onDrawEnd", onDrawEnd);
var featureLayerUrl = "http://summitmaps.summitoh.net/arcgis/rest/services/DOES_Mercator/MapServer/2";
featureLayer = new esri.layers.FeatureLayer(featureLayerUrl, {
    mode: esri.layers.FeatureLayer.MODE_SELECTION,
    outFields: ["UNAME", "INSTALLYR", "DNAME", "STREET", "EASEMENT", "INVERT", "OWNERSHIP"]
featureLayer.setSelectionSymbol(new esri.symbol.SimpleMarkerSymbol().setSize(8).setColor(new dojo.Color([160, 214, 238])));
map.addLayer(featureLayer);
function onDrawEnd(extent) {
    var newStore = new dojo.data.ItemFileReadStore({
        data: {
            identifier: "",
            items: []
    var grid = dijit.byId("manholeGrid");
    manholeGrid.setStore(newStore);
    toolBar2.deactivate();
    var query = new esri.tasks.Query();
    query.geometry = extent;
    featureLayer.selectFeatures(query, esri.layers.FeatureLayer.SELECTION_NEW, function(features, selectionMethod) {
        var items30 = dojo.map(features, function(feature) {
            return feature.attributes;
        var data30 = {
            identifier: "OBJECTID",
            items: items30
        var store30 = new dojo.data.ItemFileReadStore({
            data: data30
        var manholeGrid = registry.byId("manholeGrid");
        manholeGrid.on("rowclick", onRowClickHandler);
        manholeGrid.setStore(store30);
        map.setExtent(graphicsUtils.graphicsExtent(featureLayer.getSelectedFeatures()), true);
        gsvc = new GeometryService("http://summitmaps.summitoh.net/arcgis/rest/services/Utilities/Geometry/GeometryServer");
        var graphics = featureLayer.graphics;
        var selectedGeoms = graphicsUtils.getGeometries(graphics);
        var params = new BufferParameters();
        params.geometries = selectedGeoms;
        params.distances = [500];
        params.unit = GeometryService.UNIT_FOOT;
        params.outSpatialReference = map.spatialReference;
        gsvc.buffer(params, showBuffer);
        function showBuffer(geometries) {
            var symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
                    new Color([0, 0, 255, 0.65]), 2
                new Color([0, 0, 255, 0.35])
            arrayUtils.map(geometries, function(geometry) {
                var graphic = new Graphic(geometry, symbol);
                map.graphics.add(graphic);
            queryTaskNew = new esri.tasks.QueryTask("http://summitmaps.summitoh.net/arcgis/rest/services/Cadastral/Parcels/MapServer/0");
            var queryNew = new esri.tasks.Query();
            queryNew.returnGeometry = true;
            queryNew.outFields = ["PARID", "ADDR"];
            queryNew.geometry = geometries[0];
            queryTaskNew.execute(queryNew, showResults300);
            function showResults300(featureSet) {
                var resultFeatures = featureSet.features;
                for (var i = 0, il = resultFeatures.length; i < il; i++) {
                    var items300 = dojo.map(features, function(feature) {
                    var data300 = {
                        items: items300
                    var store300 = new dojo.data.ItemFileReadStore({
                        data: data300
                    var grid = registry.byId("parcelGrid");
                    grid.on("rowclick", onRowClickHandler);
                    grid.setStore(store300);
And here is the HTML as it pertains to the above code:
<div data-dojo-type="dijit/layout/ContentPane" title="Manhole">
                    <input type="text" id="doesManholeText" value="BA15" />
                    <button id="doesManholeSearch" data-dojo-type="dijit.form.Button" type="button" data-dojo-attach-point="button">Search</button>
                    <button data-dojo-type="dijit.form.Button" onClick="toolBar2.activate(esri.toolbars.Draw.EXTENT);">Select</button>
                    <button id="clearManholeGrid" data-dojo-type="dijit.form.Button" type="button" data-dojo-attach-point="button">Clear</button>
                    <span id="manhole-result-count"></span>
                    <table data-dojo-type="dojox/grid/DataGrid" data-dojo-id="manholeGrid" id="manholeGrid" style="height: 340px" data-dojo-props="rowsPerPage:'100', rowSelector:'20px'">
                        <thead>
                            <tr>
                                <th field="UNAME">UNAME</th>
                                <th field="INSTALLYR">Install Year</th>
                                <th field="DNAME">DNAME</th>
                                <th field="STREET">Street</th>
                                <th field="EASEMENT">Easement</th>
                                <th field="INVERT">Invert</th>
                                <th field="OWNERSHIP">Ownership</th>
                            </tr>
                        </thead>
                    </table>
                </div>
<div id="bottom" data-dojo-type="dojox/layout/ExpandoPane" title="Click the Arrow to Minimize this Panel" data-dojo-props="title: 'Parcel Search', splitter:true, startExpanded: false, region:'bottom'" style="height: 300px;">
    <div data-dojo-type="dijit/layout/ContentPane" title="Selected Parcels">
        <table data-dojo-type="dojox.grid.DataGrid" data-dojo-id="parcelGrid" id="parcelGrid" style="height: 300px" data-dojo-props="rowsPerPage:'100', rowSelector:'20px'">
            <thead>
                <tr>
                    <th field="PARID">Parcel #</th>
                    <th field="ADDR">Address</th>
                </tr>
            </thead>
        </table>
    </div>
</div>
Can anyone see why I can't get results from the second query, in this case, "queryTaskNew" into the appropriate datagrid?
Any help is much appreciated!!
RyanSellman
Bharath,
Are you able to post your code?
Ryan
bharathreddy
Hi Ryan,
Here is my code.I'm able to get infotemplate but unable to get buffer AND SELECTED FEATURES
<!DOCTYPE html>
<html>
  <head>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <title>Select with feature layer</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/tundra/tundra.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
    <style>
      html, body, #mapDiv {
        padding: 0;
        margin: 0;
        height: 100%;
      #messages{
        background-color: #fff;
        box-shadow: 0 0 5px #888;
        font-size: 1.1em;
        max-width: 15em;
        padding: 0.5em;
        position: absolute;
        right: 20px;
        top: 20px;
        z-index: 40;
    </style>
    <script src="http://js.arcgis.com/3.14/"></script>
    <script>
        var map;
        require([
        "esri/map", "esri/layers/FeatureLayer","esri.layers.ArcGISDynamicMapServiceLayer",
        "esri/tasks/query", "esri/geometry/Circle",
        "esri/graphic", "esri/InfoTemplate", "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "esri/renderers/SimpleRenderer",
        "esri/config", "esri/Color", "dojo/dom", "dojo/domReady!"
      ], function (
        Map, FeatureLayer,ArcGISDynamicMapServiceLayer,
        Query, Circle,
        Graphic, InfoTemplate, SimpleMarkerSymbol,
        SimpleLineSymbol, SimpleFillSymbol, SimpleRenderer,
        esriConfig, Color, dom
          // use a proxy page if a URL generated by this page is greater than 2000 characters
          // this should not be needed as nearly all query & select functions are performed on the client
          esriConfig.defaults.io.proxyUrl = "/proxy/";
          map = new Map("mapDiv", {
              //              basemap: "streets",
              //              center: [-95.249, 38.954],
              //              zoom: 14,
              //              slider: false
          var landBaseLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://localhost:6080/arcgis/rest/services/line/MapServer", { opacity: 5.55 });
          map.addLayer(landBaseLayer);
          //add the census block points in on demand mode. Note that an info template has been defined so when
          //selected features are clicked a popup window will appear displaying the content defined in the info template.
          var featureLayer = new FeatureLayer("http://localhost:6080/arcgis/rest/services/line/FeatureServer/0", {
              infoTemplate: new InfoTemplate("Block: ${CAP_ID }", "${*}"),
              outFields: ["CAP_AIN", "CAP_LOCATION", "CAP_DT_ID", "CAP_SS_ID", "CAP_AMPS"]
          // selection symbol used to draw the selected census block points within the buffer polygon
          var symbol = new SimpleMarkerSymbol(
          SimpleMarkerSymbol.STYLE_CIRCLE,
          12,
          new SimpleLineSymbol(
            SimpleLineSymbol.STYLE_NULL,
            new Color([247, 34, 101, 0.9]),
          new Color([207, 34, 171, 0.5])
          featureLayer.setSelectionSymbol(symbol);
          //make unselected features invisible
          var nullSymbol = new SimpleMarkerSymbol().setSize(0);
          featureLayer.setRenderer(new SimpleRenderer(nullSymbol));
          var circleSymb = new SimpleFillSymbol(
          SimpleFillSymbol.STYLE_NULL,
            SimpleLineSymbol.STYLE_SHORTDASHDOTDOT,
            new Color([105, 105, 105]),
          ), new Color([255, 255, 0, 0.25])
          var circle;
          //when the map is clicked create a buffer around the click point of the specified distance.
          map.on("click", function (evt){
              //debugger;
              circle = new Circle({
                  center: evt.mapPoint,
                  geodesic: true,
                  radius: 1,
                  radiusUnit: "esriMiles"
                  map.graphics.clear();
                  map.infoWindow.hide();
                  var graphic = new Graphic(circle, circleSymb);
                  debugger;
                  var query = new Query();
                  query.geometry = circle.getExtent();
                  //use a fast bounding box query. will only go to the server if bounding box is outside of the visible map
                  featureLayer.queryFeatures(query, selectInBuffer);
                  alert("success");
          function selectInBuffer(response) {
              var feature;
              var features = response.features;
              var inBuffer = [];
              //filter out features that are not actually in buffer, since we got all points in the buffer's bounding box
              for (var i = 0; i < features.length; i++) {
                  feature = features;
                  if (circle.contains(feature.geometry)) {
                      inBuffer.push(feature.attributes[featureLayer.objectIdField]);
              query.objectIds = inBuffer;
              //use a fast objectIds selection query (should not need to go to the server)
              featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function (results) {
                  var totalPopulation = sumPopulation(results);
                  var r = "";
                  r = "<b>The total Census Block population within the buffer is <i>" + totalPopulation + "</i>.</b>";
                  dom.byId("messages").innerHTML = r;
          function sumPopulation(features) {
              var popTotal = 0;
              for (var x = 0; x < features.length; x++) {
                  popTotal = popTotal + features.attributes["CAP_AIN"];
              return popTotal;
    </script>
  </head>
  <body>
    <span id="messages">Click on the map to select census block points within 1 mile.</span>
    <div id="mapDiv"></div>
  </body>
</html>
RyanSellman
Bharath,
I adjusted just a few minor things. The code shown below should work.  Also, I swapped out your service URLs with mine and got your code to work here:
Edit fiddle - JSFiddle
-Ryan
<!DOCTYPE html>
<html>
  <head>
   on iOS devices-->
  <style>
  html,
  body,
  #mapDiv {
  padding: 0;
  margin: 0;
  height: 100%;
  #messages {
  font-size: 1.1em;
  max-width: 15em;
  padding: 0.5em;
  position: absolute;
  right: 20px;
  top: 20px;
  z-index: 40;
  </style>
  <script>
  var map;
  require([
  "esri/map", "esri/layers/FeatureLayer", "esri/layers/ArcGISDynamicMapServiceLayer",
  ], function(
  Map, FeatureLayer, ArcGISDynamicMapServiceLayer,
  Query, Circle,
  basemap: "streets",
  zoom: 14,
  slider: false
  var landBaseLayer = new ArcGISDynamicMapServiceLayer("http://localhost:6080/arcgis/rest/services/line/MapServer", {
  opacity: 5.55
  12,
  var circle;
  map.on("click", function(evt) {
  debugger;
  geodesic: true,
  radius: 1,
  debugger;
  var feature;
  var inBuffer = [];
  feature = features;
  featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(results) {
  var r = "";
  var popTotal = 0;
  return popTotal;
  </script>
  </head>
  <body>
  </body>
</html>
