ISSUE WITH TEXT SHOWING BEFORE THE MAP IS LOADED
1149
07-23-2013 10:28 AM
JuneAcosta
Hi all,
The text that belongs to the ContentPane shows/loads on the screen before the map viewer does. Is there a way to hide the text before the app fully loads?  Here's the link:
http://gismaps.carlsbadca.gov/carlsbadclip/index.html
I spoke with someone from the Javascript island at the conference and he suggested I change the order in which I load the stylesheet in the app- I tried it, but its still an issue.
Has anyone run into this same issue? Do you have a solution?
Thanks!
SteveCole
Honored Contributor
My advice would be this:
  1. Put the offending text inside a div with a unique ID
  2. In your CSS add the "display:none" CSS property for that item
  3. At the end of your init routine, add some javascript code to reverse the CSS visibility:
theDiv = document.getElementById("<your Div ID here>"); theDiv.setAttribute("display","inline");
If you need to support an older version of IE, which code you use to set the CSS property might change. Note: Dojo also has a way to set the CSS properties of a DOM element.
Steve
SteveCole
Honored Contributor
Steve
