Issue with Popup Template on HeatMap
1427
05-22-2022 09:32 PM
KrishnakanthYachareni
PopupTemplate on HeatMap is not working in Javascript API 4. x versions. Here is the sample provided by Esri but the popup is not working there: https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=visualization-heatmap
Where in older versions of JS API it is working: https://developers.arcgis.com/javascript/3/jssamples/renderer_heatmap_weighted.html
Could someone help here with how to enable the popup option while using the heatmap in Javascript API 4.x?
ReneRubalcava
Esri Frequent Contributor
Looks like this will be fixed in 4.24, it's currently working in the "next" build. You can test by changing the script tag url.
<script src="https://js.arcgis.com/next/"></script>
ReneRubalcava
