Issue with dojo.require statement
2430
01-21-2014 06:19 AM
BrianLord1
Good Morning,
I am currently trying to set up the Citizen Service Request app (from the arcgis for local government app gallery) and continue to run into a problem.
While debugging I encounter this error...
"Microsoft JScript runtime error: xhrFailed"
The error happens everytime the script reaches the following lines.
dojo.require("js.config"); dojo.require("js.infoWindow"); dojo.require("js.date");
I have re-ordered these and the error happens no matter which one it hits first.
The files exist and within each one they start with the following code (this is from the config.js file)...
dojo.provide("js.config"); dojo.declare("js.config", null, {
Any help would be greatly appreciated.
Mark
JeffPace
does your dojoConfig say where "js" is?
i.e.
<script type="text/javascript" >             dojoConfig = {                 parseOnLoad: false,                         async:true,                 baseUrl: '/arcgis_js_api/library/3.8/arcgis/js/dojo/dojo',                 packages: [{name: 'org', location: hostPath + '/..' + '/mobile/org'},                     {name: 'agsjs', location: hostPath + '/..' + '/mobile/agsjs'},                     {name: 'com', location: hostPath + '/..' + '/js/com'},                     {name: 'utilities', location: hostPath + '/..' + '/mobile/utilities'}                 ],                 isDebug: false,                 usePlainJson: false             };         </script>
JeffPace
i.e.
BrianLord1
Thanks for the response Jeff!
Here is the code that came in the template.
<script type="text/javascript">
            var dojoConfig = {
                async: false,
                parseOnLoad: true,
                mblHideAddressBar: false,
                packages: [{
                    location: location.pathname.replace(/\/[^/]+$/, '') + '/js'
    </script>
Do I need to change something here?  None of the other templates I have used from the local government gallery have required me to change something there.
I have included a screenshot of the folder structure for this site.
Thanks again!
BrianLord1
Found the answer.
Thanks to Jeff's post, I took another look at my code and realized I had changed a variable along the way that was causing my issues.
JeffPace
glad you found it!
