Issue with controlled Calcite Switch
2447
09-25-2023 12:13 PM
FabricioBezerra
Issue:
I'm setting the Calcite Switch component's "checked" value as a controlled input, but the component's UI state does not reflect the value (images attached)
I'm using the following libraries/versions in my React application:
"@arcgis/core"
: "^4.27.6"
"@esri/calcite-components-react": "^1.8.0"
Tags (1)
omar-marji
Hello,
Did you try setting undefined instead of false when you want it to be unchecked?
This is mentioned in the gotchas part of the help. It should fix your problem I think.
https://developers.arcgis.com/calcite-design-system/resources/frameworks/#gotchas
omar-marji
Hello,
FabricioBezerra
Thank you so much @omar-marji! That fixed the issue 🎉
