Is there a way to adjust width of search widget in js api?
4812
6
02-09-2016 02:04 AM
MichaelKefahuchi
Well, the question is already in the title.
The search widget is about 280px wide, and I just need to make it about 200px to fit to my tool bar.
AnthonyGiles
Honored Contributor
Michael,
Try using the following css:
.arcgisSearch .searchGroup .searchInput {
   width:100px;
Regards
Anthony
by Anonymous User
Not applicable
Hi Michael,
Did is defined in the esri.css stylesheet (look inside it for.arcgisSearch .searchGroup .searchInput ). You could override it with your own css.
MichaelKefahuchi
Thank you Richard,
I have already played with that css selectors however without success. Here is jsfiddle if you wish to have a look:
search widget width - JSFiddle
My tries are commented out, so far nothing worked...
AnthonyGiles
Honored Contributor
Michael,
   width:100px;
Regards
Anthony
MichaelKefahuchi
Richard thank you very much. I just didn't realize that I have to use all three selectors, till I read Anthony's answer. So I am marking Anthony's answer as correct one, but it is just because it was more obvious to me. I wish I could mark both as correct.
Big THANK YOU to both of you.
KenBuja
MVP Esteemed Contributor
You can also mark answers as being helpful in addition.
MichaelKefahuchi
thanx for suggestion, I did that...
