Hello all,
I would like to add a print view button so staff can see what they will be printing. I have looked in ArcGIS API for javaScript but only found information on how to print. Seems to be a way to also print preview or view print extents.
Thanks
James,
Look at this sample
http://developers.arcgis.com/javascript/samples/widget_print_webmap/
If you hit print, it will create a pdf. The user can view the pdf and then if it is what is desired the user can then print it.
Although this was built for use with Web AppBuilder projects, this Print Plus widget is pretty nifty.
