Is there a preferred way to implement undo/redo functionality on an editable MapView?
1484
08-01-2024 11:15 AM
JMMFIRE
I'm researching ways in which I can implement undo/redo functionality on my editable MapViews. I see v3.xy had the UndoManager class that enabled this but I see no equivalent for 4.27.
Is this something that has to be handmade or am I missing some functionality with the Editor or within the MapView somewhere?
JamesIng
The Sketch widget itself maintains a redo/undo stack that you can call on, but is limited to the sketch operation itself.
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Sketch.html#event-undo
I created my own stack for operations outside of editing through the sketch widget.
James from www.landkind.com
JMMFIRE
Thanks for this! We use the Sketch widget in conjunction with the Editor to manage a diagramming tool for our client. The plan is for the undo/redo functionality to be functional across all editable layers.
