Is the ssl certificate required to publish the geoprocessing tool
6325
7
02-23-2015 03:00 PM
Chang-HengYang
Hi All,
I am wondering if I need to install ssl certificate on teh web server for the geoprocessing tool working well such as Print tool(JavaScript API).
Hank
TomSellsted
Hank,
No.  You can run geoprocessing scripts from your web server without having an SSL certificate for them.
Regards,
Tom
TomSellsted
Hank,
Regards,
Tom
Chang-HengYang
Hi Tom,
Thank you for the help.
Hank
TomSellsted
Hank,
You are most welcome!
Regards,
Tom
Chang-HengYang
Hi Tom,
I am wondering if the ArcGIS Web Adapter is required for the geoprocessing tool to work on our web map portal for the public.
Hank
TomSellsted
Hank,
No, it is not necessary.  The web adaptor allows you to integrate ArcGIS for Server with your web server.  You can still use any other published services directly from your ArcGIS server.  For example:
http://cityarc.ci.yakima.wa.us:6080/arcgis/rest/services
is the internal path to our collection of rest services
https://gis.yakimwa.gov/arcgis101/rest/services
is the path to our rest services from our web adaptor
All services function exactly in the same way.
Regards,
Tom
Chang-HengYang
Hi Tom,
Thank you for the quick updating. I am wondering if your print url in your web mapping application is linked from internal server service or external rest service (web adaptor). Or the print tool is working from both server services.
Hank
TomSellsted
Hank,
It is working from both.
Regards,
Tom
