Is operations dasboard required to run extensions
1619
07-20-2016 12:15 PM
MarvinGalicha
I'm trying to determine why widgets will not display or provide the expected service/function properly using only the ArcGIS Online version.  I've been told that operations dashboard, a windows client application, must first be installed on the local PC viewing the widgets in order for the Map Viewer in AG online to display such widgets.
JakeSkinner
Esri Esteemed Contributor
Hi Marvin,
When you refer to widgets, are you referring to the Web AppBuilder widgets?  The ArcGIS Online viewer does not support widgets.
Can you elaborate on your current workflow?
